Power steering (Rapid)
Hi.Does anyone know of a diagram showing the power steering pipes on my 2014 1.2 Rapid Spaceback. I am trying to trace a fluid leak but am unable to definitely locate these pipes. Thanks. Graham
Following on from this I stripped the battery tray to gain access to the steering reservoir. Please see pic. NO RESERVOIR !!! I had asked numerous times online where the reservoir was for my year and model Rapid.The code shows 1N1 which indicates a hydraulic system is fitted but 1N3 is for Electronic Power steering. Although the EPS warning has flashed up once the Oil/fluid leak I have been trying to trace is presumably something else. Please give me your thoughts on this.Thanks, Graham
2014 RAPID SPACEBACK 1.2 VIN - <Removed>
Please don't post VIN's publicly. This is to help prevent cloning and data theft.
Briskoda Admin
Edited by Lee01
removed vehicle identity
No reservoir is a good clue. Here's a pic of the hydraulic installation; the pipe connections to the steering unit should be obvious, too.
It may have all electric with the same pr code. I'm pretty sure I read when they changed from electrohydraulic to full electric they kept the same pr number 1n1 for standard steering and 1n3 for speed variable.
Main worry would be that where is the fluid coming from. Does it look like engine/Gbox oil or maybe brake/clutch fluid.
Alasdair
Thanks for that inspectorman. Back up on the ramps tomorrow and check all pipes and connections now I know what I am dealing with .
@gswainyboy if you'd like to reply to the message I sent to you asking for the VIN, I can look up what system you have.
Recently Browsing 1
