Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Hi ive got a build up of black soot in the coolant tank and getting pressure in the system when taking off the coolant tank cap in the morning when engine is cold it still releases a heavy hiss of air escaping, also when turning ignition on or off get a gurgling sound from behind dashboard.
Im hoping this is a broken egr cooler and not the head gasket so to check i want to bypass the egr cooler , the dpf and egr are already mapped out .
As anybody on here bypassed the coolant pipes on the egr cooler on here before ? If so what size pipe do I need ? Is it possible to do from top of the engine or do you need to get underneath it ?
Need to get underneath it. Think the pipes are around 20mm internal diameter. About to try something this weekend. Will update you if it works
So, did this myself today. Likewise, dpf and egr are mapped out. Car has been using coolant since about 100k miles. Now on 180k and worse than ever after changing everything but the head gasket. This is the last chance before I get rid of it.
Link below to the connector I used. You need under the car to get at the bottom coolant hose on the egr cooler and the top hose from the top of the engine. Once both are disconnected the connector piece is just about long enough to bring the two hoses together. You will probably make a mess even with hose clamps to try stop the flow. If you don’t have the vw hose clamp pliers for removing the hose clamps you might struggle
https://vehicleclips.co.uk/products/20mm-car-heater-breather-hose-connector-straight-nylon-pa66
Thanks for the reply , is there no way of getting to the bottom pipe from the top if I remove air intake pipes ? Can't jack my car up where I live , ive just got a 19mm connector because everywhere I looked online it said I needed a 19mm but on the plastic connector it says 18 with that circle print next to it . Was that 20mm a really tight fit ? Also mine isn't loosing coolant but got soot in the tank and bubbles in the tank with engine running was yours doing that ? And as it stopped
I think you’d really struggle to get at the bottom one. It’s not difficult to get the air intake out of the road, so maybe take it off and have a feel for the lower pipe. 20mm wasn’t a tight fit at all, you should be fine with a 19mm though and maybe have a couple of spare hose clamps incase the standard clamps aren’t tight enough. No my coolant was always clean.
A faulty egr cooler would make the coolant and tank change colour from the soot at least that's why hours of Google searching is telling me , im hoping its that and not the head gasket on mine. As yours not got a leaking hose somewhere ? Also have you tried the charge air cooler ?
Recently Browsing 1
