Headlamp Help Please
Hey all, my dads 2016 1.2 Fabia Estate has developed a ‘damp’ nearside headlamp. As you can see it’s pretty bad. I don’t see any crack in the lens or split in the upper seal, do these have vent holes that are easily accessible? Any help or suggestions would be very greatfully received! 😋
My mk2 octavia is the same. Reckon its the front lens seal thats gone. On the Octavia you can remove entire unit easily. I took it in to warm house and managed to dry it up carefully in front of fire then used a thin silcone bead around lens. Been ok for a while now. It may be that the rubber covers are loose or missing at rear as well. On the Octavia you remove plastic nut and pull a lever bellow headlight and the unit pops out. Makes bulb changes so much easier.
Alasdair
Had a look at my sons and its not the same. No quick release system. Best option would be to remove rubber seals from rear and switch lights on for a while. The heat from bulbs should dry it up. Years ago a trick if lens was glass was to put a towel over it so it heated up more and remove rubber seals at rear to vent moist air. Dont do it with plastic lenses. They tend to melt as I found out a few years ago.
Alasdair
Remove the rubber access seals for the headlamp bulbs and fire a hair drier in to the unit.
HTH
Thanks. AG Falco
Are these breather holes?
No.
Use the two holes that are covered by the rubber access seals that you have already removed in the photo above.
Unless they are missing?
Thanks. AG Falco
Recently Browsing 1
