A few questions regarding the Kodiaq – brake light, Start-Stop and Travel Assist
Hi everyone,
I have a few questions regarding my Kodiaq its a 2024 2.0 TDI 147 kW 4x4 (not the latest but the facelift from 2021-2024) and would appreciate some feedback from other owners.
  1. Third brake light: Does anyone else experience an issue where the third brake light (high-mounted brake light) briefly illuminates when using the turn signals? I noticed that on motorways in the night.
  2. Start-Stop system: Is it possible to permanently disable the Start-Stop system using OBDeleven on this models?
  3. Travel Assist: Is it possible to extend the time before Travel Assist asks me to take over steering control? At the moment, after approximately 10–15 seconds, it displays a warning asking me to take control of the steering wheel. I would like to extend this interval if possible. Can this be adjusted using OBDeleven?
Thanks in advance for any advice or feedback!
I have the same TDI200 4x4 MY 22.
1) Not paid attention to this yet. I'll take a look
2) No
3) I don't think so. Maybe @Cairus knows...
3) Yes, Change dataset from unit A5
2 hours ago, Bap33 said:
2) No
Thank you, let me know what you are gonna find out for number 1 🫣😉
Thank you. Am i on the right way?
No, the dataset is essentially an extension of the firmware. It is loaded onto a control unit and—to put it simply—contains vehicle-specific data and the functions that the control unit is supposed to execute. Tools like ODIS-E or VCP can be used to flash these datasets. There are also some handy tools that allow you to load the OEM dataset, which then provides you with a user-friendly interface for making adjustments; you can then save your configuration and flash it onto the unit.
Ok, now i understand. So i would have to go to somebody who could modify the dataset. What do you think about KLR Emulator for MQB steering wheel? You get the mainboard and just switch it with the original one under the airbag ob steering wheel 🫣😅
Edited by superB_LK
AliExpress, good Look That you finde one which good Work
I see that many of them are not working good, so i think i’m gonna leave it like it is. Maybe i just buy the memory switch for start/stop so i dont have to push the button 😉
Recently Browsing 1
