How are your EFB batteries holding up?
1 hour ago, imart143 said:
yes on eco 2 engines, but on evo 1 engine it is unlikely, The V-belt tensioner does not allow tension in the other direction, the belt could fall off, while the evo 2 tensioner is completely different.
instead,
With an eBay memory module installed behind the dashboard button, your alternator operates in a steady, conventional charging mode rather than aggressive regenerative mode—and it is actually healthier for your 12V battery over time.
How Your Alternator Works Now
  • Simulates a manual button press. Every time you turn on the ignition, the module sends a quick electrical pulse that mimics you pressing the physical Start-Stop "OFF" button.
  • Aggressive coast-only charging is disabled. Because the car's Energy Management System sees that Start-Stop is turned off by the driver, it abandons the fuel-saving "recuperation mode" (where it lets the battery drop to ~80% charge while cruising so it has empty room to absorb braking energy).
  • Constant, steady voltage. Instead of fluctuating wildly between 12.2V (cruising) and 14.8V+ (braking), your alternator now outputs a steady ~13.8V to 14.3V during normal driving.
  • Smart protection remains intact. Because the battery sensor on the negative terminal is still plugged in, the ECU still monitors battery temperature and health, tapering off the voltage once the battery reaches near 100% state of charge so it never overcharges.
What This Means for Your Car
  • Longer 12V battery life. Standard recuperation cycles constantly undercharge AGM/EFB batteries (keeping them around 75%–80%), which accelerates sulfation and shortens battery lifespan. Keeping the battery near 100% with your memory module typically makes it last noticeably longer.
  • No fault codes or side effects. Unlike unplugging the battery sensor wire, the car treats this as a completely normal user action, so all safety and convenience systems work properly.
  • Minimal fuel difference. Keeping the alternator engaged continuously adds a tiny mechanical load to the 1.5 TSI engine, resulting in a negligible fuel consumption increase (typically around 0.1–0.2 L/100 km).
Given the reference to Ebay module, presumably this charging mode isn't OEM standard ?
