Top mount
Only had my superb a few weeks. Yesterday it started making a horrendous twang. I suspected a spring , turns out the o/s top mount has left the chat. So I wanted to ask, is it a pretty straightforward DIY job. And what's a decent replacement brand to use. Its a 2016 superb estate L&K 4x4 2.0tdi 190.
Many thanks
It may be the spring that's broken too and taken the top mount with it. This is what happened on mine. I got a garage to do mine as I needed it done quickly, but I think it’s relatively straightforward if you’ve got the tools. You either have to split the hub from drive shaft to take the strut out or compress the spring in situ to remove the bottom end of the strut from the lower control arm.
I have the workshop manual I can share with you if you require it.
It would be a good opportunity to fit lowering springs/sport struts/coilovers etc etc 😃
Really good guide here:
Edited by Binx1310
It'll be worth checking your other springs as well, both my rears went, then a month or two after getting them done, both the fronts went. 2018 combi 4x4.
Probably a crater in the road that did that damage , its not a 4x4 and nor is my Mk1 Fabia but the UK roads are shi7!
You will need a couple of axle stands , spring compressors , swan neck spanner or open socket and a knuckle joint spreader, I made my own out of a bolt and grinded to suit , not great but it sort of worked. Oh yes and a blowtorch.
Budget three hours , start cleaning the threads now soak in wd40 or something stronger , take your time loosening all the bolts or you will shear them off and a even bigger job.
Was worried about compressing the spring but that was easy , hardest job was to get the knuckle on and off the strut......best done indoors now but I did mine on a bright autumn day but ran out of light and finished in the dark .....all character building stuff ENJOY x
So finally got around to tackling the top mount. Total ball ache. Then noticed what you guys have mentioned. A jagged end to the spring. Was at the very top. Just out of site. I did hit a big pot hole a couple of weeks ago . But was on the near side.
Recently Browsing 1
