[Octavia vRS 245 - 2019] Constant whistling noise under the rear seat when warm — Fuel pump?
Hi everyone,
I could not find any topic covering this specific diagnosis so here is my first real post here!
Looking for some real-world feedback before I order a replacement part for my 2019 Octavia vRS 245 (2.0 TSI 245hp, 129,000 km / ~80k miles, DKTB engine code).
The issue: Once the car is fully up to operating temperature, there is a constant, fairly high-pitched whistling noise coming clearly from the rear (under the back seat / fuel tank area). Aside from the noise, the car runs great: no warning lights, no misfires, and it starts right up both cold and warm.
What I've checked so far:
  • A mechanic listened to the noise and agrees it's likely the low-pressure fuel pump (LPFP) inside the tank.
  • I ran a few checks with OBDeleven showing the pump is working hard constantly (~70% duty cycle at idle, 85-90% under load), while everything else on the engine side (fuel rail pressure, fuel trims, EVAP purge valve) looks completely healthy.
  • The underside of the fuel tank feels completely cool to the touch.
Before I go ahead and swap in a new Bosch fuel pump unit, has anyone else experienced this exact symptom on their vRS (or a Golf GTI / Leon Cupra from the same generation)?
Did replacing the pump permanently fix the whistling, or is there anything else around the tank worth checking (tank breather/ventilation, fuel pump control module, etc.)?
Thanks in advance for any insights!
Cheers,
AD
I'll also add that the whisling noise doesn't change whether the tank is full or empty, same when the fuel tank cap is closed or open.
Recently Browsing 1
