Battery light 1.0 mpi 59bhp
Hi folks, I’m having issues with various warning lights popping up uninvited on the wife’s Fabia, but one is staying annoyingly dim - the battery light. I’m assuming like most cars this comes on during ignition and the goes out on start up normally? Only its not coming on at all. Any guidance much appreciated.
Welcome to the forum.
The alternator indicator should light with ignition switched on - then immediately extinguish when the engine starts (alternator supplying power)
If you have a multimeter, test the voltage at the battery terminals to check if the alternator is actually supplying power - should be significantly above 13 volts when engine running above idle speed.
Lack of indicator light with ignition on, engine not running suggests the indicator itself may have failed.
Could be the wire from alternator. Its the smaller exciter wire. If it breaks (they are prone to) you get no light at preignition. If its broken then the alternator may not be charging properly and causing low battery causing random warning lights. On my old Octavia I had random warning lights some full brightness and others dim. It was the cluster connection that needed cleaned and reseated. Finally worked it out when DPF light came on and as it didnt have one realised it was electrical contact issue.
Alasdair
Thank you both. Voltage at battery does vary in line with expected on a ‘smart’ alternator. I have changed the battery and all was good for a few days and then the christmas lights came back on!
I have checked the exciter wire to the plug/socket on the front of the engine block and it is good to there from the alternator. I don’t know where the wire goes from there, whether it is straight back to the ecu or to somewhere else so I can’t check further back annoyingly.
Can other mk3 owners confirm that battery light on with ignition is the expected behaviour please? I wouldn't necessarily assume that.
Edited by Breezy_Pete
I can definitely confirm that a MY18 Mk3 Fabia does.
I cannot recall any ICE vehicle that hasn't had a 'battery indicator' illuminate when the ignition was switched on if the charging system was functional.
@Tqm What are the other warning indicator lights that are lighting up?
What are the actual voltage readings you are seeing?
Edited by Warrior193
question
I'll look up later where the exciter wire originates.
BCM I expect.
BCM I expect.
I tracked it to the battery module and checked continuity and its good. I guess from there it goes to the ecu?
Regarding warning lights - non today!?!
Previously though front assist, rear parking, tpm, other tyre/wheel associated ones and occasionally stop/start. I’m guessing wheel sensor with these, but the battery light is confusing thinking. Could be 2 (or more!) different problems I guess. Random lights have been in the last 2 or 3 weeks but the battery light may not have been lighting for longer.
Will look shortly, but that may be the LIN control wire rather than the exciter.
There’s only 1 wire from the alternator connector - blue one. Goes to green/yellow from the engine block plug
Yeah, my bad. I started to type that in my first post earlier but then was struck by doubt.
There is just the one, LIN bus control wire.
Alternator right at bottom of this page. BCM right at the top. LIN data comms wire comes from alternator in blue, changes colour at 4-way connector pair to green/yellow then splits off to battery monitor control unit and BCM (Brown 46-way connector pin 26). Green dashed line shows the omitted connectivity between the two boxes labelled 18.
Circuit info for the alternator warning lamp (K2) just shows it driven by CAN info from BCM rather than showing actual electrical connectivity. So not hardware linked to alternator.
Are there two green/yellow wires emerging from pin 1 of that 4-way connector you've called 'engine block plug'? If not, I guess that splice - B549 - where the one green/yellow wire becomes two must be wrapped in the loom somewhere.
This is fantastic, thanks. There is 1 wire from the 4 way connector and I didn’t notice a splice. I’ll have another look.
The bcm is not the same as the ecu is it? Do you know where is may be physically situated?
Apart from the missing 'battery' indicator, the common cause of the others is either low battery SOC - or failing ABS wheel sensor.
What voltage readings are you seeing at the battery terminals?
Battery is new as a result of these lights and car has not been widely used since. @12.5v with nothing operating.
So, as the alternator appears to be working, does this indicate a problem on the bcm? A dud led for the battery light is unlikely isn’t it?
Not impossible for a led to fail - or a faulty track on the cluster.
Recently Browsing 1
