Skoda fabia starting issue
My 2014 Skoda Fabia will sometimes just crank and not start. If I stop and try again, it usually fires up straight away on the second attempt.
It's showing fault code P034100 - Camshaft Position Sensor Circuit Range/Performance, but the timing chain is fine. I've replaced both the camshaft and crankshaft position sensors multiple times, yet the fault keeps returning.
The car has also just come back from an auto electrician, who checked all the wiring and confirmed everything is ok and they also they repaired the ecu.
Given that the timing chain, sensors, wiring, and ECU have all been checked or replaced, does anyone have any ideas what could be causing the intermittent no-start issue where it only cranks on the first attempt but starts immediately on the second?
Which engine?
Htp 6 valve, 12 valve or something else?
It is a 1.2 htp 12 valve
Recently Browsing 2
