Skoda fabia starting issue
My 2014 Skoda Fabia will sometimes just crank and not start. If I stop and try again, it usually fires up straight away on the second attempt.
It's showing fault code P034100 - Camshaft Position Sensor Circuit Range/Performance, but the timing chain is fine. I've replaced both the camshaft and crankshaft position sensors multiple times, yet the fault keeps returning.
The car has also just come back from an auto electrician, who checked all the wiring and confirmed everything is ok and they also they repaired the ecu.
Given that the timing chain, sensors, wiring, and ECU have all been checked or replaced, does anyone have any ideas what could be causing the intermittent no-start issue where it only cranks on the first attempt but starts immediately on the second?
Which engine?
Htp 6 valve, 12 valve or something else?
It is a 1.2 htp 12 valve
I'd love to know what that means. I have my doubts that they'll even have opened it.
Who checked the chain timing and how? There are two aspects to investigate; crank to cam, and cam to cam. Cam to cam can be readily checked DIY from above, crank to cam is a bit trickier.
Edited by Breezy_Pete
I'm not too sure what they did to the ecu I think they could of reconditioned it
The chain was changed about 6 months ago by a friend that is a mechanic. The cam to cam and crank to cam was checked and were all okay
Recently Browsing 3
