5Q0 612 041 BM Brake booster vacuum hose with a non-return (check) valve and pressure sensor
Our Karoq 1.5l petrol 2018 60000 miles went for a service this week.
The report said "Vacuum hose off inlet manifold has damage to connector and will not clip into place. Advise this is replaced".
Car seemed to drive as per normal with this 'failed' part after service
The part has now been replaced - separate visit - part details off the bag are "5Q0 612 041 BM Brake booster vacuum hose with a non-return (check and pressure sensor".
So I am wondering how often this part fails and requires replacement?
Perhaps this connection tab suffered from plastic ageing?
Does this part require disconnection as part of a normal service which included the spark plugs so the plastic top engine cover has to come off, etc.?
Photos below/attached:
  • old part on the drive which shows is wiggly shape - yellow arrow indicating failed connector
  • offside of engine bay with hose identified in red
  • nearside of engine bay with hose identified in red. Yellow arrow indicates failed connector
  • failed connector, shown with red line - the 'push' tab seems to have broken and is missing
  • non failed connector with green showing the bit of the tab that has come off
Recently Browsing 1
