Rear brake pad carrier bolts-removal techniques
Does anyone have a technique or tool suggestion for removing the rear brake pad carrier bolts on Octavia mark 4 1.5Tsi. I work on my drive with a trolley jack and axle stands. I have a breaker bar but I don't have clearance anywhere. Thanks for reading.
Have you wound the pistons back with a ODB tool ?
Edited by RADIOTWO
Yes. All went fine with caliper. It’s the carrier bolts that defeated me. If I were just changing pads I would have been fine. I need to change the rotor too and this cannot be removed unless one first removes the carrier. Two very tight bolts in very awkward position.
Recently Browsing 2
