oil pressure problem
Intermittent oil pressure problem 2012 Fabia 1.2 12 engine. Random oil pressure light problem it seems to randomly come on, although more when going around a roundabout not sure if the relative though I get 3 beeps with 3 flashes, followed by 12 flashes, no beeping. The engine is high mileage, but no crank-type noises on start-up or when the pressure light is on. Tomorrow I plan to isolate the swich nd fit a temporary auxiliary buzzer. Anyone got any ideas? The oil level is just a shade above max; the oil is Drive-Tec 5 30, which I have used for the last few years with no problem
Have you unplugged the connector of the pressure switch to examine inside it for oil leakage?
changed the oil pressure switch; however, when the car is running, the level on the dipstick shows low but stopped its normal oil and filter change tomorrow
Might be debris in sump pick-up strainer.
Recently Browsing 1
