Play in between outer and inner track rod end
Just got some new tyres Michelin ps5 for the fabia that were in black Friday deal.
Tyre fitter noticed 3 to 9 o'clock play across tyre on front left wheel. Showed me it moving near lock nut which was tight.
Fitted inner track rod ends 55k ago but both outer track rod ends had split on rubber. I fitted lemforder outer TREs and new ball joints then wheel alignment. March 2025.
The play seems to be the thread holding the outer and inner TR together.
So, do I just replace 1. inner and outer TRE?
  1. Both sides inner tre and outer tree?
  1. Do both sides and think about new shocks and springs, top mounts, drop links (55k miles, 9 years on) in case shocks are problem.
At 65k last shocks were toasted but suspect due to previous owner. However on our watch rear shocks were hitting bump stops after 30k miles.
Don't you just love doing these jobs in the cold 🥶
If 3. Other than a dealer where should I get all fasteners for the strut?
Ps same number of threads visible on both track rod joints on both sides of front axle.This pic shows the affected side but really doesn't show anything unless you watch video
Edited by bmbmdmb
The thread on the inner TR is in the steering rack - so is the inner track rod tightened up correctly to the rack - or has its ball joint failed - which brand of parts were used.
Surely, with an assistant you can work out which end is causing this problem.
Recently Browsing 1
