Can it be true that an Octavia only lives 5 years
As Rob says the cutting out is more than likely a crank sensor.
Shocking way for a dealer to behave, gives us all a bad name.
thanks for all your advice on here, i would be lost without this website.
Well, if we save you more than
I would ask them to put it in writing that they have found it to be un economical to repair. Once you get that you should be laughing.
The law was changed recently to the rough effect of 'something that you buy must be fit for it's purpose and have reasonable life expectancy'.
http://www.dti.gov.uk/consumers/Fact%20Sheets/page24700.html
Some key phrases -
For up to six years after purchase (five years from discovery in Scotland) purchasers can demand damages (which a court would equate to the cost of a repair or replacement).
If repair and replacement are not possible or too costly, then the consumer can seek a partial refund, if they have had some benefit from the good, or a full refund if the fault/s have meant they have enjoyed no benefit
In general, the onus is on all purchasers to prove the goods did not conform to contract (e.g. was inherently faulty) and should have reasonably lasted until this point in time (i.e. perishable goods do not last for six years).
Q3. Are all goods supposed to last six (or five) years?
No, that is the limit for bringing a court case in England and Wales (five years from the time of discovery in Scotland's case). An item only needs to last as long as it is reasonable to expect it to, taking into account all the factors. An oil filter would usually not last longer than a year but that would not mean it was unsatisfactory.
the problem with some main dealers is they have no old school mecanics and they are soley relying on the computer software.go somwhere and find a garage where they have oily hands and they smoke roll ups.
You have a PM ;)
Saunders Abbott in Sidcup have been a bit naughty with me. I went in to have a blank key blade cut, and they refused to do it, saying i had to buy there one at £160 and get them to laser cut it. Why wouldn't take my blank key, which was identical to the one they tried to sell me ??? Bloody Stealers!!
BTW nice to see another local!
There is a guy on Ebay that cuts them from a digital image for around £10 or £12 including the blade.
OK cheers i'll have a look on there. Sorry to go off topic...
sorry if this is a bit long and drawn out!!
00522 027
sender for coolant temp - G62
implausable signal
sporadic fault
00537 018
lambda control
upper limit stop value
sproadic fault
00668 036
vehicle voltage terminal 30
01316 079
brake control unit
07978 P1570 035
engine control module disabled
sporadic fault
4 speed automatic gearbox 01N
01M927733HG
AG4 getriebe 01M 4448
coding
dealership number 24055
00293 025
multi function switch-F125
undefined switch condition
00532 035
supply voltage
01192 004
Torque converter lock-up clutch
mechanical fault
sporadic fault
ABS/EDL ITT 20 IE
1J0907379Q
ABS/EDS 20 IE CAN 0001
coding 13504
dealership number 31480
00283 035
front left speed sensor G47
00283 004
front left speed sensor-G47
mechanical fault
sporadic fault
Airbag-without side airbag
1J0909603AS
airbag VW3-V04
coding 16723
00532 007
supply voltage
signal too low
imobilizer/instument cluster
1U2919034C
A4-Kombinistr. VD0 V22
coding 2442
IMMO IDENTNR
01176 007
key
low signal
conv.system-door cont. module, front and rear
1J0959799Q
5G Zentral-SG komf. 0001
coding 4097
1U6959802B
5G Tursteuerger. FS0002r
1U6959801B
5G Tursteuerger. BF0002r
1U0959811B
5G Tursteuerger. HL0002r
1U0959812B
5G Tursteuerger. HR0002r
Any ideas greatly appeciated
you might want to edit out your imobiliser number there
Seems like alot doesnt it.
But around four of them faults are relating to a flat battery and should clear just fine.
Looks like you need to start with...
1)Coolant temp sensor
2)Multifunction switch (F125) on gearbox
3)n/s/f wheel speed sensor
So even though at first it looks quite scary three components should go a long way to sorting that lot. And none of the three components are that extrodinary.
Thanks for the advice on the parts, it does make me realise that a little attention and Octi will be fit and well again
  • 4 weeks later...
You could always buy a cable from eBay for >
  • 2 months later...
Hi Michelle_Tony,
Did you ever get yoru Octy Fixed up?
The dealer concerned is Saunder Abbott at Sidcup
Hmm. I live in NW, but travel to the Smoke a lot. I went once to their place in Croydon for some SLX II LongLife Oil, and they said Duckhams will do.......:thumbdwn:
worth putting a review of the dealers in the relevant part of the forum. b@stards.
