help
this was on another forum, I have the sat nav but does anyone know how to do this???
With SatNav and the "full size" MFD, you can.....
Change the auto lock / auto unlock doors.
Adjust the "brightness" of the footwell lighting.
turn on / off the remote opening/closing of windows and sunroof (if fitted) with the key.
Adjust the duration the headlights remain on in the leaving/coming home mode.
That's just a few things that l can think of.
John
this was on another forum' date=' I have the sat nav but does anyone know how to do this???
John[/quote']
Not sure any of that is possible throught the Sat Nav on the OctyII but I could be wrong.
-Autolocking is an option you need to get the dealer to enable through VAG.Com
-There is no footwell lighting on the OctyII
-The remote opening/closing of windows etc from the remote is 'on' by default. Not sure why you would want to turn it 'off'
-You only get the coming home/leaving home functions if you specify 'light assist' in which case you can adjust the delay times through the maxidot computer.
