elegance 4x4 T CD player not working
HI CD player stopped the other day - tape and radio still fine and swap when pushing the C/D button on player.
CD changer will not eject so it may be power lost and it is not reckognised.
No specific fuse for CD in fuse baox - have had changer out and can't find one.
Anyone had something similar ? know a solution
no idea mate but if its fubar you can have mine for £50 delivered if you like. it hasn't been used for about 2 years :)
Lift the carpet in the boot underneath the CD changer and seperate the connector there. Give it a clean out and the put it back together. If that doesn't help then you could also try checking the thing is connected ok at the head unit end.
A search on here should provide you with info on getting the removal tools (dealer is fairly cheap IIRC)
Thats a guess, but I'm not really sure.
Thanks guys, I will lift the carpet and go from there.
....A search on here should provide you with info on getting the removal tools (dealer is fairly cheap IIRC)....
I just use a 2 strips cut from a loyalty card or similar that's not needed.
