Replacing bulbs
Want to change the bulbs in my Fogs on the furby, and put some phillips silvers into the rear indicators (done front). Ordered the light's but before I try butcher the car apart anyone let me know the easiest/best procedure for replacing the two sets of bulbs.
Ta
The grills just pull off, no problems and the foglights themselves are the same procedure as in the manual, i would tell you but i haven't done it myself yet.
I think, though I'm not sure, that the front fogs just unscre/bolt from the bumper once the grilles are removed with a good tug! (Cue Jason style michael taking) ;)
The rear indicators are simple. Just pull the cloth trim inside the boot behind the lamp assembly. This just pull down, then unclip the cradle thingy that the rear bulbs sit in. Refitting is, as Uncle Haynes always says, the reverse of the removal!
Hope this helps! :thumbup:
I think' date=' though I'm not sure, that the front fogs just unscre/bolt from the bumper once the grilles are removed with a good tug! (Cue Jason style michael taking) ;)
OOOOOOHHHHHH MATRON!!!!
Cheers chaps ;)
Anyone tried getting behind the xenons?
I wanted to fit the bluevision sidelights, but I'm having trouble :(
They are a even a pain to change in the standard Lights, so my advice is to use a band aid to cover the cuts with.
