Building new front suspension?
So you can adjust chamber and caster and so on..
Has anyone done it here? John?
IIRC you can adjust toe but not caster or camber.
I'm talking about a REBUILD so you can adjust chamber and caster. I know it's not adjusteble as standard.
Yes you can. Not done it myself, so not sure of how easy it is to do. You'd need to get some adjustable top mounts made up. Not sure about the caster though. I'll have a hunt around.
Humble apologies :dunce:
Is the camber not adjustable to some degree on the bottom balljoint?
I thought you could move the balljoint on the three 13mm bolts and slide it in and out of the lower arm?
Ross, you can, but its very hard to do with any accuracy. Better to design something better from scratch.
FK make adjustable topmounts when you find stock let me know i want some.. then camber is moveable to many options..
what company is FK?
do they have a homepage?
Sorry Turbo2,
My post No.5 didn't come out as I indended. It has now been edited.
