Rear speakers in Fabia vRS?
Well, can anybody tell me which speakers fits in the rear?
As far as I can see on www.blaupunkt.com and www.pioneer.com one says that is 130 cm speaker the other says it is 5x7" (oval speaker).
So can anybody confirm what fits in the rear and is it possible to fit 165cm in the rear?
/Jonas R.
The rear speakers are 4 inches or 10 cm's
That was very small, is it possible to fit something bigger?
/Jonas R.
Would be tricky to fit bigger woofers where the rear speakers are normally. Whether other woofers could be fitted into the parcel shelf? I guess so? Or go the whole subwoofer route. It should be possible to fit uprated tweeters OK in the rear doors though.
Dont really want to use the rear parcel shelf. Will look into some 10cm speaker then.
Planning to run Hertz Hi-Energi HSK 165 in the front with a JVC headunit. A Audison LRX5 and 12" Phase Linear in the trunk. Will look into the rear speakers and see what i can fit there. Hope i can squees in some 130 cm :)
/Jonas R.
  • 6 months later...
if you want bigger speakers in the rear have you thought about a stealth shelf from auto acoustics and a pair of 6x9's
Thats what I've done... Shelf... Amp... 6x9s. Sounds great!
