windows that stop halfway
when i press teh windows switch, which operates the one-touch function or the drivers door window. it only goes halfway down then stops!! but if you press it again it goes all the way down to the bottom. and it only does it when opening the window.
there's no fault codes logged either.
does anybody elses fabia fo this??
Try giving the seals on the top of the door a clean out and lub them up with some silicone spray.
that's a top quality idea stu, i'll try that later on methinks
