What oil for a 1.4tdi pd?
Hi, I
Have you searched on here? Same as Fabia vRS etc.
i allways laugh at all this fancy oil stuff that poeple insist you use!!! i allways put 10-40 semi in mine. and at 170k miles it was still running like a gold watch.
Hi' date=' I’m trying to find out what oil my 1.4tdi Pd meant to take?[/color']
I've quite cleverly put my fabia user books somewhere so safe that I don’t lose them, to the extent that I’ve forgotten where I’ve put them :S
And Google’s having a bad day...
And for any TDI PD engines make sure you use the recommended oils or you could finish up with a very expensive repair bill.
Exactly. With the high loading and fine tolerances of the roller rocker system it is vital the correct and tested oil grade is used.
