any ideas to what this part is?
My 51 plate Octy Vrs went in for a 40,000 mile service and cam-belt change and when I got home I noticed this piece of rubber on my scuttle panel. It measures about 2" long by 1" wide.
I can't see anywhere obvious under the bonnet where it should go and not even sure if it is off my car.
Any clues would be appreciated! I do have other vews but they are to big to put onto one post.11123.attach
Looks like the plug that fits into a whole in the gearbox bell housing, they would have removed it to check that they had the engine timing set correctly.
If you look at the gearbox where it mounts to the engine, you should be able to see the whole where it sits.
HTH
Correct!
Amazed as usual at the level of random knowledge on this site!!
Cheers for replies and the dealer who carried out the service has e-mailed me quoting the same thing but will confirm on Monday.
If it's only an inspection hole cover then no damage will be done driving I presume?
No damage, but would suggest it goes back ASAP. It stops any little debris falling inside and possibly causing damage.
