Memory loss
Just installed a JVC KD-G311. 50 watts per channel. The sound quality has improved tremendously:rofl: . The standard speakers are handling the increased power and does not sound like they are busted:D .
I have one problem. Each time I switch the ignition off or remove the face of the system, it loses all of the settings. thats is, bass, treble, loudness etc.
Is there anything that can be done apart from changing the head unit
Braff
take it out and swap red and yellow over, these are the switched and permanent 12v feeds.
easy job.
easy job.
:iagree: Also retains where you were on the CD, instead of starting over from the beginning. :)
Hi Guys, had a look at the wiring to the head unit and i cant seem to find the red and yellow wire. There are 2 connectors, Brown and Black, and the wires are connected as follows
Brown
1 - Blue
2 - Blue and Brown
3 - Red
4 - Red and Brown
5 - Blue and White
6 - Brown and White
7 - Red and Green
8 - Green and Brown
Black connector
1 - Blue and white
2 - Vacant
3 - Grey and White
4 - Red and Yellow
5 - Red and white
6 - Blue and Grey
7 - Red and White
8 - Brown
The brown connector sits above the black one.
I hope this help you help me
Braff
we're not talking about the main loom for the car but instead the short loom that goes from the ISO plug to the HU plug, normally manufacturers don't iso on the actual unit to save space and use their own plug type so supply you with a short(about 6") bit of loom. its on this bit of loom that the yellow and red cables normally have bullet connectors in the middle so you can swap them over easily :)
this sort of thing, if it doesn't have bullet connectors then just cut the cables in the middle and fit some :)
Problem sorted. Thanks guys
good to hear :)
