Octy 1 change from cassette to cd?
I've the cassette with 6 disc changer, can I change the cass to a cd unit and still use the changer?
This request is a long running saga!
I believe it is possible, but only if you don't mind tinkering with the connections (which in most cases isn't worth the hassle with the latest headunits able to play MP3/AAC/WMA or DVD) The Skoda multi changer is usualy produced by Grundig or Panasonic so there are some compatability issues. Search the threads to get an idea and then make your mind up before you take the plunge into buying a new head unit.:thumbup:
I just plugged in a CD unit and it worked fine with the CD changer without any tinkering.
assuming its a skoda cd unit, then yes its a straight swap.
