Milltek + Xenons???
Hi guys,
After searching through the threads abot Millteks and Blueflame exhausts, there doesn't seem to be any mention on whether they were fitted to cars with xenons or not.
The reason I ask is due to Milltek saying the exhausts are not suitable for cars with xenons due tot he sensor being on the rear axle, but when I had a look under the car there should still be room for a bigger pipe around that area?
Has anyone with xenons fitted an aftermarket exhaust to their furby, and did they have any problems?
Irf
Mine has Xenons and a full Milltek.
It was on when I bought it though, so I can't say if there were any problems in fitting it.
i think people have fitted them with xenons , but it is a pain to hang it so it doesn't foul the sensor on the axle , judicious bending of hanger brackets will be required
JBS fitted my turbo-back Milltek and I've got Xenons. Never had any problems, and I can still adjust the Xenons OK.
There were no problems mate. It fitted like a glove...:)
Thanks for the replies guys. Looks like it'll either go on no probs or there'll be a slight adjustment to do around the sensor :)
It is a tight fit with a BF, you may need to adjust the heatshield a little.
There were no problems with the blueflame on mine. I had it fitted at Blueflame in Skelmersdale.
Very tight on the BF as Stu said, it took a lot of effort to stop it sliding out of position as well due to the brackets sliding around - clipped them up in the end...
Been fine since, but if you load the rear of the car up it does still hit :(
