Got myself a new vagcom laptop
A fairly tatty IBM Thinkpad 600E.
Good ol Ebay should sort you out for the battery.
Was just looking as it happens. It seems whether I go local or far away, it's
TBH I'd say a cig lighter converter might be more useful, it should work just fine and it isn't that expensive any more either IIRC
I'm doing a few trial charges and run flats to see what happens. :D
Edit: Last running time was 10 minutes from charged to flat, with a little bit of Windows XP tour it decided to take me on. Hoping that the more I flatten it, charge it, and so on, it will exercise the battery and maybe improve it a bit. If I can get it to about half an hour of life, that will do me to be honest.
:o Muppet here hadn't altered the settings for the power and screensaver, so after 10 minutes it was going into standby / sleep mode. :D
So, turned all that off and it looks to have a battery life of around 1 hour. :cool:
1 hour isn't too bad on an old machine like that if it is doing stuff.
Well, I left it just sitting on desktop during it's tests. I had a go on the pinball game though. :o Looks a promising £30 spent at the moment. :cool:
What sort of spec laptop do i need to use VAG COM with???
I have been thinking about getting an old laptop just for this purpose but am unsure as to what CPu/Memory/hard drive requirements are?
Just need a serial port to use a serial port cable. My cable is the official ross-tech cable with the white box in the middle of it. :) The laptop need not be anything special. Mine's a P2 and it seems to run Windows XP OK - certainly better than the install of windows 98 on it when I got it first....
