What do I do now?
Hello all,
This is my first post so please be gentle on me!
I own a '52 plate' Skoda Fabia 1.4 Classic. It has 32,000 on the clock. I have had it from new and had it fully serviced by Skoda during the 3 year warranty.
A few weeks ago my engine management light came on. I took it along to my local Skoda dealership. The fault came back as a purge value or related issue. They cleared the fault from the ECU and advised me to hope that it does not come on again.
Well, it did. Back to Skoda who then replaced the Purge Valve (
No idea, but good luck finding a solution. Welcome to the forum :wave:
Sorry to hear about your problems - hope you get them sorted soon!
i would take it back to the dealer that fitted the £100 part that hasn't fixed your fault and ask them to rectify it , also ring Skoda customer services and explain what has happened to see if they can get the dealer to sort it with some goodwill gesture
  • 6 months later...
Hello All,
I am getting the same problem in my car. I just got the EMS erased yday and its now backon. Should I take it to Skoda dealer instead of local garage?
Thanks,
Vinayak
From - 16825/P0441/001089 - Ross-Tech Wiki
16825/P0441/001089 - EVAP Emission Control Sys: Incorrect Flow
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
contact your local trading standards they might be able to give you advice.
