help !!! beeping
Hi People
Please can you assist me? both my father and own 54 plate fabia VRS', The problem with his furby is that when he starts the engine (quite regularly) it beeps
3 or 4 times and he says there are 2 warning lights on dash too.
As usual the dealer says this is normal. dont think so mine hasnt done it once!!
I'm a ex tech so told him to try no seatbelt, out of gear and clutch depressed but still happens ANY IDEAS?????????
Also on mine when engine idling with air con off it misses a beat every 10-15 seconds any help on this one would be greatly appreciated.
Which warning lights are illuminated?
Low temperature? Low washer level? Handbrake on when driving off?
Could also be low coolant, especially if it only does it when cold.
checked all that,will check which light but think abs and engine management,but will get back to you
Slightly O/T - does anyone know whether VAG-COM can disable the screenwash low beep? Anyone in midlands fancy earning a pint?
you don't need VAGCOM to disable the beep , just a jug of water will do :thumbup:
Yes you can.
Always one clever git! :rofl:
If it's the ABS and engine light it could be the same problem my Superb had, Faulty ABS control module = very expensive.
no there is no lights on when it beeps, i tried it out of 70 times did it once,then it can do it 5 times in a row,not handbrake ,coolant or screen wash.
not seatbelt,am well stuck, dealer told the old man is was perfectly normal????
mine doesnt do it.
ANY MORE IDEAS ???????????
can somebody pm with the company name, website or phone number of the company in york that does leather retrims please
Seat surgeons
