low temp beep
hi can you turn the low temp beep of on a 56 plate vrs as i am a driving instructor and as the temp goes up and down all day it does my head in :orb_duh:
richard
I've not seen a way to do that.
That's not to say it cant be done. It may also work by disconnecting the outside air temp sensor in the front bumper.
I guess it must be possible SOMEHOW, although if Stu doesn't know maybe not? The only reason I say this is that my wife's Comfy doesn't 'ping' when the temperature drops below 4 deg C, but my vRS does. The clock changes to the temperature gauge on both our cars, however!
:confused:
i wouldnt mind finding out if i can lower the temperature a bit before it comes on 4 degrees is a bit high
