wet floor
rear floor wet
que?
sandy crack
I thought my threads were wierd! :D
rear floor wet
Hmmm, annoying when that happens.
Well assuming nobody has purposely or accidently left the wetness on the rear floor, there might be a leak?
That being the case, if you've got a Yeti - I haven't heard of this before, but would get back to the dealer ASAP!
I can however comment on a Fabia with a rear wet floor, the dealer advised all four of my door seals were leaking and have since been replaced. The wet rear floor appears to have dried-up.
I hope this helps.
I had a problem with a 97 Octavia getting wet in the boot area. One of the sun roof drains had detached itself behind the boot trim ( the vertical carpet peice between the wheel arch and the back of the car)
Bulb out
rear floor wet
I had the same problem...on both reaer doors..you will have to fill certain gaps inside the door panels with silicone to solve the problem. The water goes inside beside the wind shields when raining or after car wash.
