Tuning box
Recommend me a tuning box for the 2.0tr 140 PD.
Ideally I'd like something that is switcheable.
Ta.
Adrian
To make one internally switchable then you need to run the power cable from the battery via the interior and back to the tuning box. If you just want on and off in no great rush then most have a blade fuse close to the battery connection, pulling this should make it a pass through - It does on the Dragon's anyway.
Adrian
Or failing that, you can just unplug the connections from the fuel rail/pump/sensor and return the car to standard in a matter of seconds :rofl:
Chris
Not so simple in the digital ones oh wise one!!
They piggy back the larger main engine/chassis connector which can be rather troublesome to undo.
If the box is neatly installed then it is easier to leave it in place and pull the fuse.
REVO is switchable, apparently. :P
