Fabia 1.4 TDi 80 engine oil
Just had my 1.4 TDi 80 10,000 mile service done by Pilling Skoda in Milton Keynes. The invoice says that 4.4 litres of "Castrol SLX Long Tec" have been used. I've not come across that before - I presume it's suitable for the 1.4 PD engine?
Thanks,
Mike.
First of all, VAG recommend Castrol to be use in all their engines.
Secondly, the Long Tec oil is the SLX III oil that they use in most VAG engines now. It is used in just about all, if not all, of their engines when they are set up for "Long Life" or "Variable" servicing regimes.
iirc its a fully synthetic oil where the old "PD" oil was only a semi synthetic.
So yeah, absolutely fine in your engine.
  • Sponsor
News to me!
Castrol is one of the oils they recomend.
If you look at the VAG group Fuchs do most of the factory fill etc.
Thanks,
Mike.
It does not matter which make of oil you use as long as it is to these Volkswagen specifications
505.01 (semi synthetic) 506.01 (full synthetic)
I can not imagine the Skoda main dealers putting the wrong oil in but I must admit I have not heard of "Castrol SLX Long Tec" being used in PD engines. It could be a good idea to check if the oil they have refilled with is one of the above specifications . Using any oil other than these could result in a very expensive engine rebuild or at the worst a new engine.
Worried now - the only data sheet I have found on the Internet for Castrol SLX Long Tec says that it is only 505.00. There is a Castrol SLX Long Life that meets the specs - I wonder if it is an error on the invoice? Better check with them when I take the service book in to be stamped today.
Castrol themselves recommend Edge Turbo Diesel 5w-40 oil for your car. The sump capacity is also only 4.2 litres so where did the other 0.2 go?!!
Went and spoke to them at lunch time. They did indeed use the SLX III fully synthetic oil but it always comes up on the computer as Longtec, apparently!
Mike.
Mike.[/quote
Here is a list of VW PD engine oil suppliers 505.01 and 506.01
I dont want to seem a doom merchant but I should check whether you have the proper oil in or not thoroughly because I carnt see Castrol SLX111 on the list.
As they say it must have 505.01 or 506.01 on the can if it isnt it is definitely wrong
AD Parts AD SDI SAE 5W-40 50000/50500/50501
Addinol Addinol Light MV 0546 PD SAE 5W-40 50000/50500/50501
Agip Agip 7004 SAE 5W-40 50000/50500/50501
Aral Aral Tronic 431 SAE 5W-40 50000/50500/50501
Avia Avia Turbo CFE PD SAE 5W-40 50000/50500/50501
Bucher AG Motorex Profile V-XL SAE 5W-40 50000/50500/50501
Castrol Castrol 505 01 SAE 5W-40 50000/50500/50501
Castrol Castrol GTD 505 01 SAE 5W-40 50000/50500/50501
Cepsa Cepsa Star TDI synt SAE 5W-40 50000/50500/50501
Chevron Havoline 505.01 SAE 5W-40 50000/50500/50501
Conqord ROLOIL 505.01 SAE 5W-40 50000/50500/50501
DEA DEA Ultec Diesel SYN SAE 5W-40 50000/50500/50501
DEA DEA Viscobil ST SAE 5W-40 50000/50500/50501
Delek Israel Delkol IDI SAE 5W-40 50000/50500/50501
Denicol Motor Oils Denicol Pro Syn 4 SAE 5W-40 50000/50500/50501
Elf Elf Excellium DID SAE 5W-40 50000/50500/50501
Esso Esso 505 01 SAE 5W-40 50000/50500/50501
Eurolub (Hunold) Eurolub Synt PDI SAE 5W-40 50000/50500/50501
FL Italia Pulsar Progress SAE 5W-40 50000/50500/50501
FL Italia Selenia Performer SAE 5W-40 50000/50500/50501
Fuchs Fuchs Motorenoel G052 167 02 SAE 5W-40 50000/50500/50501
Fuchs Labo Syntha High Tech Synthese SAE 5W-40 50000/50500/50501
Fuchs Motorenoel G 052 167 02 SAE 5W-40 50000/50500/50501
Fuchs Titan Supersyn SL-F SAE 5W-40 50000/50500/50501
Ginouves York 742 SAE 5W-40 50000/50500/50501
Hunold Hunold Synt PDI SAE 5W-40 50000/50500/50501
Igol Igol Process 505.01 SAE 5W-40 50000/50500/50501
Kuttenkeuler Sorotec Pdi SAE 5W-40 50000/50500/50501
Kuwait Petroleum Q8 Motoroil 505.01 SAE 5W-40 50000/50500/50501
Liqui Moly Liqui Moly Diesel High Tech SAE 5W-40 50000/50500/50501
Meguin megol Motorenoel Super Leichtlauf Technology SAE 5W-40 50000/50500/50501
Millers Oils Millers XFE-PD SAE 5W-40 50000/50500/50501
Mobil Mobil Syst S Special V SAE 5W-40 50000/50500/50501
Mobil Mobil TD SAE 5W-40 50000/50500/50501
Molyslide Molyslide Formula L2 SAE 5W-40 50000/50500/50501
Motul Motul 6100 SAE 5W-40 50000/50500/50501
Oest Mineralölwerk Oest Leichtlauföl 505.01 SAE 5W-40 50000/50500/50501
PAZ Champion Oil 50501 SAE 5W-40 50000/50500/50501
Pentosin Pentosynth 5W-40 TS* SAE 5W-40 50000/50500/50501
Petrogal Galp Formula 505 Extra SAE 5W-40 50000/50500/50501
Ravensberger Schmierstoffvertrieb Ravenol VPD SAE 5W-40 50000/50500/50501
Repsol Repsol Elite 505.01 TDI SAE 5W-40 50000/50500/50501
Rowe Rowe Synth PD SAE 5W-40 50000/50500/50501
Shell Shell 505.01 SAE 5W-40 50000/50500/50501
Slovnaft Madit 505 01 SAE 5W-40 50000/50500/50501
Sonol Sonol Synt 505.01 SAE 5W-40 50000/50500/50501
Statoil Statoil Superway SAE 5W-40 50000/50500/50501
Sun Oil Sunoco Ultra semi synth. SAE 5W-40 50000/50500/50501
Suomen Petrooli OY Teboil Diamond SAE 5W-40 50000/50500/50501
SWD swd Primus Synth. SAE 5W-40 50000/50500/50501
Tamoil Sint Future Extra SAE 5W-40 50000/50500/50501
TD Lubrifiants AVIA TDi 505.01 SAE 5W-40 50000/50500/50501
Teboil Teboil Diamond Diesel SAE 5W-40 50000/50500/50501
Total Total Quartz 505.01 SAE 5W-40 50000/50500/50501
Unil Opal Unil Opal Opaljet 505.01 SAE 5W-40 50000/50500/50501
Valvoline Diesel Turbo motot oil SAE 5W-40 50000/50500/50501
Valvoline High Performance Diesel motor oil SAE 5W-40 50000/50500/50501
Valvoline Valvoline Diesel Turbo Motor Oil SAE 5W-40 50000/50500/50501
Valvoline Valvoline High Performance Diesel Motor Oil SAE 5W-40 50000/50500/50501
Vaps Vapsoil PD 540 Spezial SAE 5W-40 50000/50500/50501
Veedol Veedol 505 01 SAE 5W-40 50000/50500/50501
Westfalen AG Westfalen Megatron SAE 5W-40 50000/50500/50501
Wolf Wolf Masterlube Synflow PI SAE 5W-40 50000/50500/50501
Würth Würth Triathlon Special PD SAE 5W-40 50000/50500/50501
Yacco Yacco Spéciale SAE 5W-40 50000/50500/50501
Yacco Yacco VX 505 Diesel SAE 5W-40 50000/50500/50501
Zeller+Gmelin Divinol Syntholight 505.01 SAE 5W-40 50000/50500/50501
