Couple Of Questions... Coolant & Wheels
Hi folks
Im new to car ownership, and own a 2000 (w) Fabia 1.4 Classic in a dark green :)
I am looking to spruce it up slightly, and since i'm on my first year, insurance is extortionate :(
I am looking at some alloy wheels, and though they are expensive relative to the cost of the car (which i will think about changing in a year or 2) i have taken the view that they can be removed and i can replace the standard wheels and trims, and put the alloys on my next car (hopefully a little sportier :D )
Konig Helium 17" Set of 4 wheels and tyres Slate Finish
Those are the wheels in question, i have read about spacers and so on, now is there someone who can advise on anything i might need as far as extras goes ?
Second question - car runs fine etc, no leaks, but the coolant sensor decides it wants to make a beep when i start her up, and the red light remains on all the time :/ . Now reading around i have come to the conclusion that its the temp sensor. Any advice on how to proceed with this ? Can i change it myself ? Where would i get the part ?
Any feedback appreciated.
welcome to Briskoda , surely putting bigger wheels on your otherwise standard car is going to cost you more in insurance , you will have to declare them otherwise you wont be insured in the event of a crash
which red light ? coolant level warning or coolant temp warning , what does the coolant temp gauge say ?
is the coolant at the right level?
Would be declared, and i dont think my insurers charge, will have to check though obviously :)
Its the coolant temp warning light, the dial stays low down, settling at the half way point.
All fluids etc are topped up correctly :)
Thanks for the welcome :)
if the gauge is reading correct there maybe a problem other than the sensor
might be a dealer job to see if there are any fault codes
Well, the guage stays at the very bottom for most of the time, if i go on a long journey (30miles + ish) the guage stays at the bottom on the motorway, but when i slow to 30ish through towns etc after sustained 70/80 mph it goes to the middle as it should and the red light goes off ...
thermostat and/or temp sensor fault , i'd get them looked at/changed first
Worth having a look in the For Sale section on here for Alloys, or maybe check out Ebay - find out what other cars have the same stud pattern etc as the Fabia (Golf Mk IV's???)
I've just bought a set of new alloys for my Octy II off Ebay. The price I paid is about the same as what the tyres are worth, so in effect I got the alloys for almost nothing.
Thanks for the input, did have a scout around ebay previous (and the fs section) and all i found were VW replicas in crappy chrome :s :p
Take these for example
eBay.co.uk: AUDI TT 17" ALLOY WHEELS A3,VW GOLF,BEETLE,SKODA,SEAT (item 320065480368 end time 30-Dec-06 09:37:04 GMT)
Would they be interchangeable with the fabia, they claim to fit the octavia... sorry if this question is stupid :o ... but we all start somewhere :p
Octavia/Golf/Leon/TT/A3 wheels will physically fit , but will need different tyres than those the wheels come with to be the correct rolling radius for the Fabia. Polo and Ibiza wheels (5 stud) would fit straight on , along with their tyres.
Thanks for that dmac :)
On another note, i also am looking at these
OZ Super Turismo GT 16" Set Of 4 Wheels & Tyres Race Silver Finish
Whats the state of play with general aftermarket alloys (not OEM) ... fit all cars or ? Anyone offer any insight on the spacers mentioned earlier ? What they do etc ...
Aftermarket alloys usually have to be ordered fot the car you want them for! IE you could find lots of OZ alloys on Ebay , but some would fit Focus , others Mitsubishi , others Skoda ect but they would all be the same model of alloy wheel , so you would have to look for ones that would physically fit the bolt holes of your car (as I mentioned above Golf, Bora, A3, New Beetle,Seat Leon and Toledo (old shape)-would need tyres to be the correct size so as not to screw with your speedo , wheras Polo , Ibiza (5 stud wheels only!) and Fabia alloys will fit straight on with the tyres you buy them with)
Coolant? Before getting the clever bits checked; Check the connector into the ball shaped reservoir. It can look alright at first glance but has come loose or makes a bad connection. This has given me the same symptoms you describe (not to mention the panic when it suddenly happened in the carpark).
HTH
