Fitting springs..
To go with my suspension question asked earlier i think i will be going for some eibach springs, How easy is it to change the springs ?
I have got some spring clamps so this is not a problem...
Backs are a doddle. Fronts are reasonably easy if you have the VAG tool to open up the bottom of the hub (?) and pretty annoying if not :rofl:
Chris
Hmmmm.... what can be used instead of this vag tool !?
We used a chisel but it was a right PITA. The VAG tool is only a couple of quid and I'm sure vRStu has posted up a part number for it somewhere.....
Chris
Ahhh ii will have a search for this part number...
Found it in a matter of seconds :) So relatively easy job with this tool then.... Anybody done a guide !?
