Does the Stream ICE have an AUX input if you do not specify the Jumbo box on the vRS?
As above!
I want the aux input but am not too bothered about the duel zone climate or jumbo box.
Steve
PS Tried search but cannot find a definitive answer!
Does nobody know?
Not even the Skoda salesman knew mind!
Steve
Hi Steve,
As long as you have the newer Stream MP3 unit, then the AUX IN connection is present.
However, you would need to wire up a socket in order to be able to use it.
If you check out the pinout diagrams on this page (thanks to VRStu):
Octavia-vRS.com - MFD2 Install Guide
you will see that the connections are present on the headunit, but they are unconnected unless you specify the dual zone climate and jumbo box.
Not sure about this, but you may also need to use something like VAG-COM in order to enable the AUX IN feature on the Stream unit.
Hope this helps,
Bagpuss.
Thanks!
Steve
