big yellow's wet boot
:rofl: hi i have a problem with water running in my
boot not the gutter when i open it.
is there a trim i could get or will i have
to make them myself
take it easy cheer's
don't you just hate this?? I know I do :mad: , not sure there's much you can do, it's a common problem with most modern hatches that don't have gutter-edges to channel the water..
It's a very common problem on Octavias.
Some people have "fixed" it with a bit of silicon sealant on the edges
Or I believe the other option is to open the boot slowly.....
noooo :( doesn't work for me.. especially if the galss and paintwork are clean/waxed and the water is beaded, there's so much water that needs to run off it has nowhere to go but off the edge :( . I've tried brushing the worst off before I open the tail, but still goes in.
Its a feature, they even included it on the mk2 :rofl:
It is nice to know all the best bits are included on the mk2 then :-) Fortunately I have an estate so I miss that pleasure... I just get the fabic grab handle the gets in the boot rubber seal when closing and therefor sucks in damp spray from the road.....
Guess you could carry a water blade in the drivers door card for this purpose.
cheers everybod for having the time to share your equatic views
cheers
