engine management light on VRS
Hi Guys,
My engine mangement light has come on. Ive taken it to my garage and they've put it on the computer and the reading came out with two faults both regarding air flow. Unfortuneatly i don't have the specific codes.
Anyway they reset it and the light went out, but about a day after it came on again. Ive noticed no dip in performance and the car is driving normal.
Any idea what it could be?!!
Dan.
Is the car modified?
Could be an indication of a Boost leak.
No it's not been modified.
If it is a boost leak will that be hard to find?
It would be ideal if you could find out the codes.
Have you tried the search, I remember a code about air flow but can't be sure what it was.
Its going back in on the 2nd so they can have a further look at it, but i will try and get the codes off them while im there.
if it was a boost leak should i be noticing any dip in performance?
