Part Number Request
Hi, I found this forum from seatcupra.net as have an ibiza cupra, im doing a brake upgrade using the 312mm redrilled discs from an octavia vrs which fit on perfectly,and have TT brake lines only thing is i need the matching vrs banjo bolts which I dont have.... Does anyone have some spare I can buy or know the part number?
Apologies if this is in the wrong section
banjo bolts? WTF? Never heard of them. Are these carrier bolts? or something else?
It might be N 104 657 01 but I cn't really tell without more accurate description. :)
Do you mean the Banjo bolt for the hose/caliper connection? If so the ones on the TT hoses fit the 312mm calipers.
Yes this is the part, I thought they were slightly different? I bought them from someone who also had them on an ibiza but he used braided hoses from a leon cupra as said the TT bolt didnt screw in tightly enough, ive bought TT hoses and hoped the vrs bolts would do the job :confused:
thanks for your help, need to trim the 2.5 mm lug....
All of the TT hoses I have seen have the bolts already in.
mine didnt have, have got some bolts on the way now though :)
