How easy is it to remove the Fabia glovebox??
Got the Mrs a Parrot Bluetooth car kit for Christmas, had to remove the pull out drawer and refit the plastic cubby hole as with all the new loom there isnt enough room.
Was thinking about looking at the option of dropping the glovebox for more space as she wants the drawer refitting.
ACSC;)
5 torx bolts. 3 inside the lid when the lid is down, and 2 lower down on the outside at the extreme left and right. might be another sneaky one, but I think its only 5.
That's it, although you need a short driver to remove the 3 internal ones or you will mark the door.
Watch out when you drop it down for the air con hose and the light cable.
If you are fitting a car kit then you might also want to remove the stereo at the same time, it makes things easier.
Thanks gents,
I'll have a look on sunday then, the stereo has been out to fit the kit last weekend, just ran out of time so fitted the cubby hole instead of the drawer.
ACSC:thumbup:
Its Torx20 fitment as well. :)
Thanks matey, saves me messing about then!!!
ACSC:thumbup:
