Filling issue
Hi There
I've had a new Fab VRS since late December and seem to be having an issue filling the thing up with fuel. First time ok, full tank, second and third time at different garages the pump kept stopping as if the tank was full. If I feather the trigger I can get some fuel in, but very slowly. Took me about 5 mins to stick
i think there is someone on here with a similar fault to you with his Fabia , all i can say is try different methods/positions with the nozzle to get the fuel in , sometimes mine is a bit of a PITA when the nozzle is all the way in , but pulled out a third of the nozzle length and its OK
you could also try flicking the little nipple sticking out of the R/H/S on the neck this releases the air pressure in the tank
