Cigarette lighter fuse?
Dont know if this has been discussed much, a penny fell in my cigarette lighter and well, you can imagine the resuls, lots of sparks to say the least.
I need to change the fuse as have toys i need to power through the lighter.
Does anyone know where the fuse is located? if it is easy to change? is it a DIY or garage job?
Takes less than a minute to do, there's a fuse box layout map on here somewhere.
Open the drivers door , the panel you need to remove is on the side of the dash.
Use a screwdriver to lever it up in the small opening.
Fabia-vrs.com - Fuse Panel Layout
#42 - 15a blade fuse.
