suspension, shocks, bushes ???????
hi. i think my suspension is goin on my car. any tips on how to know for sure. also what kind of things will need changing. the car makes a noise while going over speed humps which doesn't sound healthy. its not hitting underside of car. thanks:confused:
first thing to check is the anti roll bar drop links.... these can make a terrible noise when the joints get worn or loose
My suspension might be bust too....
Damaged Arb brushes sure gives of a loud bang when going over speedbumps and on other rough surfaces. But as I myself have had the arb replaced replaced a year ago, I dont think that is my problem.
Could it be down to other brushes in the suspension setup, or is it more likely a damper/spring problem?
Its also not only the front messing up, but the rear as well...:thumbdwn:
control arm bushes is my guess... I'm having mine replaced at the next service on wednesday ;) common problem apparently.
not finshed yet but most of it is there
changing suspesion bushes
nice guide there :) If I had any tools and a garage I'd give it a go myself! lol... :thumbup:
Are the drop links different to the bushes?
If so is there a how to guide? And where you can order these drop links and how much they are?
the drop link is a straight metal bar with a ball joint at each end
dont try to undo the nuts with the weight of the car still on the suspension... you will need an allen key(5mm i think??) and a spanner (16mm)
hth:D
Yeah - That makes sense - What would cause the drop links to need to be replaced and how are the inspected? If it is just a metal rod then where along the rod will they fail?
Am I missing something crucial here ?
Also how much would you expect a pair to be ? And finally how long would you expect them to take to install.
Cheers guys!
The drop-links are a common problem, definately warranty... or even goodwill if the car is out of warranty.. other than that its a simple cheap job to do :)
They have been modified.
As mentioned above they arent just a metal rod, its the ball joints at either end that give the grief.
Cheers guys
Any ideas where to pick them up from - Would I need to buy a new rod or is it just the ball joints.
Euro Car Parts didnt have them
no the ball joints cannot be seperated from the rod.... i paid £25 squids for a pair from my local motor factors.... iirc they are £17 each from skoda
