terminal 30, where is is ?
Hi all, need some info, i need to check the power cable from battery to inside car, i need to check any relays, fuses that affect power to the cabin, where are all the relays kept ???? like flasher for indicatores etc etc.......
what route does the power cable take from the battery....
spevie
still trying to solve the flashing ind problem...
Under the steering wheel.
take the panel off with the light switch in
cheers for that,
well next installment, i set about checking all the light connections...............
i removed the rear light clustor connection and it stopped the dash flashing, so removed the other side to check connections....now i removed all the bulbs and reseated, put back together and no flashes on the dashes, started car still no flashes, revved it no beeps....turned it off, put lights on no flashes or beeps, turned ignition on and still no beeps, turned of all ok, then i got a single beep with no flashes, am i correct in thinking that you get 1 audible beep if there is a fault with a bulb ?????what else do you get with a single audible beep....
will check that terminal 30 tomorrow, i need to eat n drink, not had a thing yet today.......buisy with drabia checking ??
spevie
Terminal 30 is just a permanent positive supply.
All Fabia lighting is controlled by the Central Electrics Contol Unit (address word 09)
poasted, All Fabia lighting is controlled by the Central Electrics Contol Unit (address word 09)
can some one enlighten me as to where this is so i can check it out.......
thanks
spevie
Its under the drivers panel by your knees.
It's located under the drivers side knee panel on the right hand side. Black unit with lots of plugs going into it.
