Front tweeters
Does anyone know what you have to do do to get at the tweeter in the front door (by the bottom corner of the window down by the wing mirror). The haynes manual isn't exactly detailed, all it says is to remove the cover to access it!
I think you have to get rid of the rest of the door trim first:
1. Wind down the window
2. Remove the three Torx screws from along the bottom edge
3. Unclip the sections of the armrest and remove the screws behind
4. Lever off the trim just in front of the door handle and remove the screw behind that
5. Pull the trim away from the door body, and unclip the various connectors before removing the whole thing
6. At this point, I believe the tweeter cover should just unclip...
HTH
