Rough idle
Could this be caused by a faulty MAF sensor? It's not very rough, just more so than it used to be :confused:. I also have a slight stutter around 3k revs in certain conditions - usually when the external temperature is low.
Thanks!
It's worth checking the engine teperature sender, especially if you notice lower fuel consumption. If thats not yor problem, I would get the throttle body cleaned.
I am not a mechanic, but from other posts with similar symptoms, others have found these to be problematic.
Thanks for your responce. Is the temperature sender the same one which is used by the temperature gauge? If is then I think it is a bit dodgy!
Yes it is.
