GPO not being applied
We have a Terminal Server in are DMZ.
Problem is when logging on, GPO's are not being applied. The guy incharge of the firewalls reports their are no errors in the logs.
Any ideas?
We had all kinds of issues getting our frontend exchange server to communicate with the AD server across a firewall. In the end it was the firewall at fault, everything appeared to be working and not being blocked but due to a fault in the firewall software it was being blocked.
The event ID is 1054
"Windows cannot obtain the domain controller name for your computer network. (An unexpected network error occurred. ). Group Policy processing aborted. "
When a do a gpupdate /force I get the same error.
The firewall is blocking pings to the dc's so I had a feeling it was detecting a slow network as it cant ping so stopping gpo's from processing. But after changing the local gp it didnt work.
By using nltest /dcgetdc:domain I get my dc info.
Do the other apps work on the terminal server.
Try installing the 2003 adminpak.msi file and see if you can access "active directory users and computers". and actually see the ad contents.
No need. Think I've found the problem using userenv.logs "dsgetdcname failed with 59"
How to troubleshoot Group Policy object processing failures that occur across multiple forests
ICMP is disabled.
Just had the guy allow ICMP to the 3 dc's for now and it works.
Thanks anyway guys.
Oh and Mannyo dont think my last thread about system restore is over
Their is a reg file (well their should be :rolleyes: ) to disable slow speed connections.
Oh and Mannyo. Dont think my last thread about system restore is over :rofl: Once I get some time I'm back on it :thumbup:
I was about to say that that rang a bell and I thought ping was used to determine link speeds (it won't be in Longhorn apparently)
