just a thourght.
ok. this has been ratling aroun me brain for some time now.
as some of you might know, my car is lowered by 35mm.
what i'm thinking is, how might this have affected the brake ballance sencer on the rear beam. as the car is sitting lower, the brakes thing there is a heavy load in the back when there isn't. obviosly this is effecting how the brakes work.
any ideas????????
Yep, it should have been re adjusted.
dam it, no one told me when i did the dam thing. o well, looks like thats the naxt job.
how much do you think i need to move it by?
Only you will be able to tell that when your doing it, assuming it isnt seized solid anyway.
do you think i should take it the the stealer,
if yours had abs then dont worry because the master cylinder will have pressure sensitive ports...
if yours doesn't have abs it does need adjusting, it's just one nut oand bolt iirc, trouble is you need to adjust it with the wieght of the car still resting on the suspension so it's difficult to do at home
ha. your right, not evan an ethiopian on i diet can get under my car.
what i used to do with my polo's was find a large kerb and reverse the back of the car up onto it and then shimmy under the car to udjust it
yer, i do that with the ramps. cant go up them forwards so its gota be reversed up.
well that was befor the deer eat half me bumper, could probly drive up um easy now. :rofl:
