key programming
i have a v reg felicia i was just wondering if you can program your new
key via the vag cable also what cable is the best to get
thanks
sean
Need a cable, registered version of VAG-COM and your SKC (Secret key code).
SKC should have been on the plastic tag provided with the car when it was new.
If not, I think it is still possible to get one from the stealers??? Anyone know if they can still supply them? VW dealers aren't supplying them, due to the GEKO system.
You can also use certain OBD tools to recover the SKC, PM me if you need more info on this.
cheers guys i will order a cable
thanks
sean
