Help With Vag-com Please!!!!
Hello I need a little help with vag-com that I recently downloaded and a cable bought from e-bay , now the query i have is that when i run a scan for fault codes it will scan the engine for faults and then move onto ABS when this happens it says " you need a registered version to scan " but instead of moving onto the next section of the scan it stops , is this correct or am i doing something wrong? Also on certain scan areas I get another message which says " controller not responding" what does this mean?
Any help on this would great , thanks in advance Scott :D
Software version is 409.1-S and cable is from XXLTECH Cardiagnostic
Where did you download VAG COM?
hello i downloaded vag-com from ross-tech
I shall trnasfer you to the VAG COM section then.
But as its not a genuine lead i dont know how much help you will get from them.
Have you read the links and the FAQ's at the top of the section?
Auto-Scan is only available in the full/registered version. Since you are using the shareware you need to scan the modules manually/individually.
If a control module does not respond, its most likely not installed.
